Nisantha > 18.11.2011, 08:23 PM
Administrator > 19.11.2011, 07:59 AM
Nisantha > 19.11.2011, 05:17 PM
Administrator > 19.11.2011, 07:19 PM
Nisantha > 20.11.2011, 12:31 AM
Uwe0110 > 26.12.2011, 01:13 PM
w1th0utnam3 > 26.12.2011, 02:28 PM
w1th0utnam3 > 26.12.2011, 05:02 PM
Dec 26 15:39:31 tango3 user.err kernel: ata1: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x2 frozen
Dec 26 15:39:32 tango3 user.info kernel: ata1: soft resetting port
Dec 26 15:39:32 tango3 user.info kernel: ata1: SATA link down (SStatus 0 SControl 0)
Dec 26 15:39:32 tango3 user.warn kernel: ata1: failed to recover some devices, retrying in 5 secs
Dec 26 15:39:37 tango3 user.info kernel: ata1: hard resetting port
Dec 26 15:39:37 tango3 user.info kernel: ata1: SATA link down (SStatus 0 SControl 0)
Dec 26 15:39:37 tango3 user.warn kernel: ata1: limiting SATA link speed to 1.5 Gbps
Dec 26 15:39:37 tango3 user.warn kernel: ata1.00: limiting speed to UDMA/133:PIO3
Dec 26 15:39:37 tango3 user.warn kernel: ata1: failed to recover some devices, retrying in 5 secs
Dec 26 15:39:42 tango3 user.info kernel: ata1: hard resetting port
Dec 26 15:39:43 tango3 user.info kernel: ata1: SATA link down (SStatus 0 SControl 10)
Dec 26 15:39:43 tango3 user.warn kernel: ata1.00: disabled
Dec 26 15:39:43 tango3 user.info kernel: ata1: EH complete
Dec 26 15:39:43 tango3 user.info kernel: ata1.00: detaching (SCSI 1:0:0:0)
Dec 26 15:39:43 tango3 user.notice kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Dec 26 15:39:43 tango3 user.info kernel: sd 1:0:0:0: [sda] Result: hostbyte=0x04 driverbyte=0x00
Dec 26 15:39:43 tango3 user.notice kernel: sd 1:0:0:0: [sda] Stopping disk
Dec 26 15:39:43 tango3 user.warn kernel: sd 1:0:0:0: [sda] START_STOP FAILED
Dec 26 15:39:44 tango3 daemon.notice ntfs-3g[696]: Unmounting /dev/sda1 ()
Dec 26 15:41:01 tango3 user.err kernel: ata1: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x2 frozen
Dec 26 15:41:01 tango3 user.info kernel: ata1: hard resetting port
Dec 26 15:41:02 tango3 user.info kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 0)
Dec 26 15:41:02 tango3 user.info kernel: ata1.00: ATA-8: WDC WD10EACS-00D6B1, 01.01A01, max UDMA/133
Dec 26 15:41:02 tango3 user.info kernel: ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 0/32)
Dec 26 15:41:02 tango3 user.info kernel: ata1.00: configured for UDMA/133
Dec 26 15:41:02 tango3 user.info kernel: ata1: EH pending after completion, repeating EH (cnt=4)
Dec 26 15:41:02 tango3 user.err kernel: ata1: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x1
Dec 26 15:41:03 tango3 user.info kernel: ata1: soft resetting port
Dec 26 15:41:03 tango3 user.info kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 0)
Dec 26 15:41:03 tango3 user.info kernel: ata1.00: configured for UDMA/133
Dec 26 15:41:03 tango3 user.info kernel: ata1: EH complete
Dec 26 15:41:03 tango3 user.notice kernel: scsi 1:0:0:0: Direct-Access ATA WDC WD10EACS-00D 01.0 PQ: 0 ANSI: 5
Dec 26 15:41:03 tango3 user.info kernel: ata1: dev 0 max request 256 sectors (lba48)
Dec 26 15:41:03 tango3 user.notice kernel: sd 1:0:0:0: [sda] 1953525168 512-byte hardware sectors (1000205 MB)
Dec 26 15:41:03 tango3 user.notice kernel: sd 1:0:0:0: [sda] Write Protect is off
Dec 26 15:41:03 tango3 user.debug kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 26 15:41:03 tango3 user.notice kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec 26 15:41:03 tango3 user.info kernel: sda: sda1
Dec 26 15:41:03 tango3 user.notice kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Dec 26 15:41:07 tango3 daemon.notice ntfs-3g[746]: Version 2010.10.2 integrated FUSE 27
Dec 26 15:41:07 tango3 daemon.notice ntfs-3g[746]: Mounted /dev/sda1 (Read-Write, label "", NTFS 3.1)
Dec 26 15:41:07 tango3 daemon.notice ntfs-3g[746]: Cmdline options: nosuid,nodev,noatime,nodiratime,nls=utf8,max_read=131072,max_write=131072
Dec 26 15:41:07 tango3 daemon.notice ntfs-3g[746]: Mount options: nosuid,nodev,nodiratime,nls=utf8,max_read=131072,max_write=131072,allow_other,nonempty,noatime,fsname=/dev/sda1,blkdev,blksize=4096
Dec 26 15:41:07 tango3 daemon.notice ntfs-3g[746]: Ownership and permissions disabled, configuration type 1
Uwe0110 > 27.12.2011, 02:34 PM
AprilWine > 27.12.2011, 04:35 PM
