Festplatte (hdd) per telnet mit ext3 formatieren
rübenzähl > 27.03.2012, 11:20 PM
Hi,
ein ordentliches Linuxdateisystem, mit den Vorteilen mehr Sonderzeichen und tieferen
Pfaden etc. geht anscheinend auch:
$ telnet x10
Trying XXXXXXXXX ...
Connected to XXXXXXXXX.
Escape character is '^]'.
tango3 login: root
Password:
[tango3:~]fdisk /dev/sda
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0xb2f3441c.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
The number of cylinders for this disk is set to 243201.
There is nothing wrong with that, but this is larger than 1024,
and could in certain setups cause problems with:
1) software that runs at boot time (e.g., old versions of LILO)
2) booting and partitioning software from other OSs
(e.g., DOS FDISK, OS/2 FDISK)
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): p
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xb2f3441c
Device Boot Start End Blocks Id System
Command (m for help): n
Command action
e extended
p primary partition (1-4)
p
Partition number (1-4): 1
First cylinder (1-243201, default 1):
Using default value 1
Last cylinder, +cylinders or +size{K,M,G} (1-243201, default 243201):
Using default value 243201
/dev/sda1 1 243201 1953512001 83 Linux
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
[tango3:~]fdisk -l
[tango3:~]mkfs.ext3 /dev/sda1
mke2fs 1.40.4 (31-Dec-2007)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
244203520 inodes, 488378000 blocks
24418900 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=0
14905 block groups
32768 blocks per group, 32768 fragments per group
16384 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
102400000, 214990848
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 36 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
[tango3:~]reboot
